メインコンテンツにスキップ
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
必要な工具と部品
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: 手順 1、 1の画像 1
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 2、 1の画像 1
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 3、 3の画像 1 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 3、 3の画像 2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 3、 3の画像 3
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 4、 2の画像 1 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 4、 2の画像 2
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 5、 1の画像 1
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 6、 2の画像 1 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 6、 2の画像 2
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 7、 1の画像 1
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 8、 2の画像 1 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 手順 8、 2の画像 2
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
終わりに
作成者
2人の作成者と共同で作成されました。
Giancarlo Marruffo
メンバー登録日: 09/18/16
2 ポイント
1ガイドが承認済み
チーム
Pasco Hernando, Team 5-1, Prince Fall 2016 Pasco Hernando, Team 5-1, Prince Fall 2016人のメンバー
PHSC-PRINCE-F16S5G1
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 2,160
