メインコンテンツにスキップ
Fender Frontman 15r Reverb Tank Replacement
必要な工具と部品
  1. Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: 手順 1、 2の画像 1 Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: 手順 1、 2の画像 2
    • Remove 6 Phillips screws securing the back plate.
    • Lift the back panel out of the amp.
    • Gently pry with a flathead screwdriver or other tool to release the back panel if it's stuck.
    • Be careful not to pull out the wires connected to the power converter.
  2. Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: 手順 2、 2の画像 1 Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: 手順 2、 2の画像 2
    • Saw the adhesive from in between the reverb tank and the cabinet until the reverb tank is released.
  3. Fender Frontman 15r Reverb Tank Replacement, Free the Connecting Wires: 手順 3、 1の画像 1
    • Use wire cutters to remove the zip tie fastening the wires to the speaker.
  4. Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: 手順 4、 2の画像 1 Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: 手順 4、 2の画像 2
    • Unplug the wires leading from the reverb tank to the motherboard.
    • Notice they are plugged in where the motherboard is labeled "reverb only."
  5. Fender Frontman 15r Reverb Tank Replacement, Remove Reverb Tank: 手順 5、 1の画像 1
    • Remove the reverb tank.
  6. Fender Frontman 15r Reverb Tank Replacement, Install New Reverb Tank: 手順 6、 1の画像 1
    • Glue the new reverb tank into place following the directions provided with the glue or epoxy of your choice.
  7. Fender Frontman 15r Reverb Tank Replacement, Test the New Reverb Tank: 手順 7、 1の画像 1
    • Reconnect the wires and test the new reverb tank ensuring the effect properly matches the knob setting.
終わりに
Sam Omiotek
メンバー登録日: 02/25/19
76,055 ポイント
288のガイドは作成済み
2 件のコメント
I guess there is 2 versions of this amp the one in this video this version of the tank has 3 springs; this looks like 2…
Wonder which one was the newer version?
https://www.youtube.com/watch?v=o856fDGI...
John Ender - 返信
Interesting! I wouldn’t know which is the newer version, but the one in the YouTube video does look like it has higher quality parts…
Sam Omiotek -
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 2,436
