メインコンテンツにスキップ
Fender Frontman 15r Mounting Bracket Replacement
必要な工具と部品
  1. Fender Frontman 15r Mounting Bracket Replacement, Back panel: 手順 1、 1の画像 1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Mounting Bracket Replacement: 手順 2、 1の画像 1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Mounting Bracket Replacement: 手順 3、 1の画像 1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Mounting Bracket Replacement, Mounting Bracket: 手順 4、 2の画像 1 Fender Frontman 15r Mounting Bracket Replacement, Mounting Bracket: 手順 4、 2の画像 2
    • There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
  5. Fender Frontman 15r Mounting Bracket Replacement: 手順 5、 1の画像 1
    • Label and unplug the two red wires connecting the mounting bracket to the speaker by pulling them off the nodes.
  6. Fender Frontman 15r Mounting Bracket Replacement: 手順 6、 3の画像 1 Fender Frontman 15r Mounting Bracket Replacement: 手順 6、 3の画像 2 Fender Frontman 15r Mounting Bracket Replacement: 手順 6、 3の画像 3
    • Use a Phillips #1 screwdriver to unscrew the four 36.4 mm screws holding the mounting bracket to the top of the amp.
  7. Fender Frontman 15r Mounting Bracket Replacement: 手順 7、 3の画像 1 Fender Frontman 15r Mounting Bracket Replacement: 手順 7、 3の画像 2 Fender Frontman 15r Mounting Bracket Replacement: 手順 7、 3の画像 3
    • Pull the mounting bracket free from the frame. It may be wedged in very snug, in which case, use a plastic opening tool/spudger to pry it loose from the front.
終わりに
Once the old bracket is removed, install the new one by following the instructions in reverse.
作成者
5人の作成者と共同で作成されました。
Greg Sawers
メンバー登録日: 09/27/12
91 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S24G30
5 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 23
今までの合計 4,900
