メインコンテンツにスキップ
Fender 65 Twin Reverb Speaker Replacement
必要な工具と部品
  1. Fender 65 Twin Reverb Speaker Replacement, Speaker: 手順 1、 2の画像 1 Fender 65 Twin Reverb Speaker Replacement, Speaker: 手順 1、 2の画像 2
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier.
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Speaker Replacement: 手順 2、 2の画像 1 Fender 65 Twin Reverb Speaker Replacement: 手順 2、 2の画像 2
    • Make sure to unplug the power cord and have the amplifier turned off.
    • Unplug the audio cable running from the port labeled "INT. Speakers" to the audio speakers.
    • You should know have clean access to the speakers.
  3. Fender 65 Twin Reverb Speaker Replacement: 手順 3、 3の画像 1 Fender 65 Twin Reverb Speaker Replacement: 手順 3、 3の画像 2 Fender 65 Twin Reverb Speaker Replacement: 手順 3、 3の画像 3
    • Locate the wire leads on the speaker that you are replacing. Notice that there are three wires and four connections.
    • Note where each wire goes. (White is positive and black is negative.
    • Remove the wires from the speaker leads.
  4. Fender 65 Twin Reverb Speaker Replacement: 手順 4、 3の画像 1 Fender 65 Twin Reverb Speaker Replacement: 手順 4、 3の画像 2 Fender 65 Twin Reverb Speaker Replacement: 手順 4、 3の画像 3
    • Remove all the screws on the perimeter of the speaker. Use locking pliers to remove the nuts. There are eight bolts holding the speaker in place.
    • Pull the old speaker off of the board and insert the new speaker the same way you removed the old one.
    • When tightening the nuts back down on the bolts, be sure to tighten them by alternating, working in diagonals. (i.e. once you tighten one down go diagonal from it and work on the next one.
    • Repeat with the other speaker if necessary.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ryan Brown
メンバー登録日: 02/20/14
210 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-27, Maness Winter 2014 Cal Poly, Team 9-27, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G27
5 メンバー
7のガイドは作成済み
2 件のコメント
Thanks for the tutorial.
csharpconsultant - 返信
Am I missing a step here? You have the chassis in the way to access to speakers. Do u remove the chassis or do you remove the tolex with the speakers attached to it? Thanks
Albert - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 21
今までの合計 6,427
