メインコンテンツにスキップ
Fender 65 Twin Reverb Power Tube Replacement
必要な工具と部品
  1. Fender 65 Twin Reverb Power Tube Replacement, Power Tube: 手順 1、 3の画像 1 Fender 65 Twin Reverb Power Tube Replacement, Power Tube: 手順 1、 3の画像 2 Fender 65 Twin Reverb Power Tube Replacement, Power Tube: 手順 1、 3の画像 3
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier. You will find the four power vacuum tubes are the largest ones on the left side.
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Power Tube Replacement: 手順 2、 3の画像 1 Fender 65 Twin Reverb Power Tube Replacement: 手順 2、 3の画像 2 Fender 65 Twin Reverb Power Tube Replacement: 手順 2、 3の画像 3
    • Using the cloth, you can then remove a tube by pressing up on the two metal flaps near the top of the tubes, while lightly pulling the tube down.
  3. Fender 65 Twin Reverb Power Tube Replacement: 手順 3、 2の画像 1 Fender 65 Twin Reverb Power Tube Replacement: 手順 3、 2の画像 2
    • Check the tube for any cracks in the glass. also check to make sure the filaments are not burnt out.
    • A new or working tube should look like the one in the picture, no cracks or broken filaments.
    • If you buy a replacement tube, it is recommended that you buy one that is the same as the original and made by the same company.
  4. Fender 65 Twin Reverb Power Tube Replacement: 手順 4、 2の画像 1 Fender 65 Twin Reverb Power Tube Replacement: 手順 4、 2の画像 2
    • Take the new replacement tube (or your old one if it is still working) and insert it into the appropriate slot, pressing lightly but firmly. Make sure that the prongs at the end line up with the correct holes.
    • You should hear a click when the tube is secured in place.
    • Repeat these steps with the other three tubes if necessary.
ゴール
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Laura Kawashiri
メンバー登録日: 01/22/14
276 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 9-27, Maness Winter 2014 Cal Poly, Team 9-27, Maness Winter 2014人のメンバー
CPSU-MANESS-W14S9G27
5 メンバー
7のガイドは作成済み
コメント 1 件
What about Bias adjustment??
steffengronlikaroliussen - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 17
今までの合計 5,479
