はじめに
The brakes on anything that moves are practically the most important part. One of the most frightening feelings is pulling a brake lever and not getting a response. With this guide I hope to never make this a reality for anyone.
This guide contains information on how to replace the brake pads on a 2013 Felt Z85 Road Bike. This guide only requires one tool (4mm allen key) and is fairly straightforward.
This guide can also be used as a reference for any modern road bike with Dual-Pivot brakes.
  1. Pull up on brake-release lever to spread pads for easy access. Release lever on the right side of the wheel. Loosen left nut on wheel until wheel comes free.
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Locate Brake Caliper. Use 4.0 mm allen key to remove main bolt. Rotate counterclockwise to loosen.
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
      • Rotate counterclockwise to loosen.
      • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  4. Brake Pad: The item being replaced. Spacer: This item will be reused.
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
まとめ
Ryan Marschall
メンバー登録日: 2014年10月11日
123 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-21, Donnelly Fall 2014 USF Tampa, Team 1-21, Donnelly Fall 2014人のメンバー
USFT-DONNELLY-F14S1G21
1 メンバー
1のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 755
