はじめに
Use this guide to repair the clear indicator light. This guide will help you through replacing the light bulb.
  1. Make sure toaster is unplugged.
    • Make sure toaster is unplugged.
    • Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
  2. On the left hand side, unscrew the middle screw.
    • On the left hand side, unscrew the middle screw.
  3. Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
    • Remove the panel on the left hand side. The indicator light is located in the red tube that has wires covered by black tubing coming out.
  4. Pull the black wires to remove the indicator light from the red tube.
    • Pull the black wires to remove the indicator light from the red tube.
  5. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  6. Use scissors to cut open cord sheathing and peel back. Use scissors to cut open cord sheathing and peel back.
    • Use scissors to cut open cord sheathing and peel back.
  7. Use the wire-cutters to remove the light bulb.
    • Use the wire-cutters to remove the light bulb.
  8. Solder the replacement light bulb back onto its original position. Solder the replacement light bulb back onto its original position.
    • Solder the replacement light bulb back onto its original position.
  9. Use electrical tape to reseal the sheathing.
    • Use electrical tape to reseal the sheathing.
  10. Reinsert the indicator light back into the red tube.
    • Reinsert the indicator light back into the red tube.
  11. Turn toaster upside down so screws on bottom side are facing toward the ceiling and the door is facing towards you.
  12. On the left hand side, screw the middle screw back in.
    • On the left hand side, screw the middle screw back in.
まとめ
Tony Wang
メンバー登録日: 2012年10月05日
64 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 6-35, Regan Fall 2012 Cal Poly, Team 6-35, Regan Fall 2012人のメンバー
CPSU-REGAN-F12S6G35
4 メンバー
6のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 509
