メインコンテンツにスキップ
Fairphone 1 Motherboard Assembly Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Fairphone 1 Motherboard Assembly Replacement, Motherboard Assembly: 手順 1、 3の画像 1 Fairphone 1 Motherboard Assembly Replacement, Motherboard Assembly: 手順 1、 3の画像 2 Fairphone 1 Motherboard Assembly Replacement, Motherboard Assembly: 手順 1、 3の画像 3
    • Use tweezers to remove the volume rocker and power buttons from the display assembly.
    • During reassembly make sure the orientation of the buttons is correct. The rubber backings must fit into the channels in the assembly.
  2. Fairphone 1 Motherboard Assembly Replacement: 手順 2、 1の画像 1
    • Use the flat end of a spudger to disconnect the antenna cable connector.
    • Make sure to only disconnect the connector from its socket, and not the entire socket from the board.
  3. Fairphone 1 Motherboard Assembly Replacement: 手順 3、 2の画像 1 Fairphone 1 Motherboard Assembly Replacement: 手順 3、 2の画像 2
    • Use tweezers to remove the adhesive foam tape from the top of the digitizer cable ZIF socket.
  4. Fairphone 1 Motherboard Assembly Replacement: 手順 4、 3の画像 1 Fairphone 1 Motherboard Assembly Replacement: 手順 4、 3の画像 2 Fairphone 1 Motherboard Assembly Replacement: 手順 4、 3の画像 3
    • Use the tip of a spudger to flip open the tab on the digitizer ZIF connector.
    • Use tweezers to pull the digitizer cable away from its socket on the motherboard.
  5. Fairphone 1 Motherboard Assembly Replacement: 手順 5、 1の画像 1
    • Remove the three 2.5 mm Phillips #000 screws securing the motherboard to the display assembly.
  6. Fairphone 1 Motherboard Assembly Replacement: 手順 6、 2の画像 1 Fairphone 1 Motherboard Assembly Replacement: 手順 6、 2の画像 2
    • Do not try to remove the motherboard just yet, as it is still connected to the display assembly by the display data cable.
    • Gently lift the top end of the motherboard up to expose the display data cable.
    • The rear-facing camera may be adhered to the display assembly. Try to pry it and the motherboard up together.
  7. Fairphone 1 Motherboard Assembly Replacement: 手順 7、 2の画像 1 Fairphone 1 Motherboard Assembly Replacement: 手順 7、 2の画像 2
    • Use the tip of a spudger to disconnect the display data cable from the back of the motherboard.
  8. Fairphone 1 Motherboard Assembly Replacement: 手順 8、 1の画像 1
    • Remove the motherboard from the display assembly.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,825 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,366
