はじめに
Use this guide to replace a nonfunctioning earpiece speaker in your Fairphone.
必要な工具と部品
With the indentation as leverage, use your fingernail to pry the bottom portion of the back cover from the phone.
Use a fingernail in this indentation to push the battery toward the top of the phone
Pull the battery out away from the phone.
Use your finger to slide the SIM card straight down out of its tray.
Remove the SIM card from your Fairphone.
Remove the five 3.9 mm Phillips #000 screws securing the midframe to the display assembly.
Use the tip of a spudger to gently pry the speaker up from the display assembly.
Remove the speaker.
8 の人々がこのガイドを完成させました。
