はじめに
Before starting this guide:
Unplug the machine from any power source
必要な工具と部品
Set aside the following
The drip tray grid
The drip tray
The housing cup holder
Remove the two Phillips #2 screws at the top of the divider
Remove the two Hex 3mm screws securing the bottom of the divider
Carefully tip the divider down
The pressurestat should be covered by a small plastic clip-on protector. Remove it.
Use two crescent wrenches to remove the pressure stats. The bottom nut will unscrew while the top is used for grip.
Remove the wire connections by sliding them carefully away from the pressurestat
The pressurestat has a spring tension system which can be adjusted the turning the plastic gear
ある他の人がこのガイドを完成しました。
