メインコンテンツにスキップ
ExoPC Slate Battery Replacement
必要な工具と部品
  1. ExoPC Slate Battery Replacement, Battery: 手順 1、 1の画像 1
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
  2. ExoPC Slate Battery Replacement: 手順 2、 2の画像 1 ExoPC Slate Battery Replacement: 手順 2、 2の画像 2
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
  3. ExoPC Slate Battery Replacement: 手順 3、 3の画像 1 ExoPC Slate Battery Replacement: 手順 3、 3の画像 2 ExoPC Slate Battery Replacement: 手順 3、 3の画像 3
    • Remove the tape covering the metal shield as shown in the image.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
  4. ExoPC Slate Battery Replacement: 手順 4、 1の画像 1
    • Remove tape from the side of the battery.
    • Disconnect the battery from the motherboard.
    • Gently remove the battery.
終わりに
作成者
2人の作成者と共同で作成されました。
Aaron Moore
メンバー登録日: 10/30/18
217 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G1, Peak Fall 2018 UMass Dartmouth, Team S2-G1, Peak Fall 2018人のメンバー
UMASSD-PEAK-F18S2G1
3 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 590
