メインコンテンツにスキップ
Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement
必要な工具と部品
  1. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Dust Cup: 手順 1、 2の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Dust Cup: 手順 1、 2の画像 2
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Brush Roll Cover: 手順 2、 2の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Brush Roll Cover: 手順 2、 2の画像 2
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 3、 3の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 3、 3の画像 2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 3、 3の画像 3
    • Pull up and unhook the two front tower latches using two fingers. These are located at the base of the tower.
    • Pull up and unhook the latch on the back of the tower.
    • Firmly lift the vacuum tower up and out of its stand.
    • The exhaust filter cover can be replaced once the tower is removed. It will not affect the steps.
  4. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 4、 2の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 4、 2の画像 2
    • Remove the four 20mm screws on the top of the vacuum head's cover using a JIS 1 screwdriver.
  5. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 5、 2の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 5、 2の画像 2
    • Turn the vacuum head so that the back is facing you.
    • Press the handle release pedal.
    • Rotate the top of the motor cover down while pressing on the pedal release.
    • The motor cover should rotate from an upright position back towards the ground, as it would if the handle were still attached.
  6. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 6、 3の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 6、 3の画像 2 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 6、 3の画像 3
    • Locate the two tabs on the back of the cover.
    • Pull up on the tabs and lift the cover away from the device.
  7. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Belt Latch Assembly: 手順 7、 2の画像 1 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Belt Latch Assembly: 手順 7、 2の画像 2
    • Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
    • Remove the two 20mm screws using a JIS 1 screwdriver.
  8. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: 手順 8、 1の画像 1
    • Lift up on the belt latch assembly and remove it from the vacuum.
終わりに
作成者
3人の作成者と共同で作成されました。
Grayson Clendenon
メンバー登録日: 10/02/17
571 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S4-G5, Livingston Fall 2017 Cal Poly, Team S4-G5, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S4G5
3 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 857
