メインコンテンツにスキップ
Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement
必要な工具と部品
  1. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement, Brush roll: 手順 1、 1の画像 1
    • Unplug the vacuum from the outlet.
  2. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 2、 1の画像 1
    • Use a damp paper towel to clean the bottom of the vacuum of any debris.
  3. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 3、 2の画像 1 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 3、 2の画像 2
    • Flip the vacuum over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 3.0 mm screws.
    • Use a Phillips #2 screwdriver to remove the two 4.2 mm screws.
  4. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 4、 1の画像 1
    • Pull the bottom and top cover of the brush roll compartment apart.
    • Internal components of the vacuum may fall out during this step, so keep track of where they are located for reassembly.
  5. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 5、 3の画像 1 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 5、 3の画像 2 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 5、 3の画像 3
    • Lift the brush roll out of the vacuum.
    • The brush roll is connected to two white placeholders on both left and right sides. To remove these, pull them away from the brush roll.
  6. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 6、 1の画像 1
    • Thoroughly clean the inside of the vacuum with a damp paper towel and let it dry.
  7. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 7、 2の画像 1 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 7、 2の画像 2
    • To replace the brush roll, attach the two white placeholders on both ends of the brush roll and set them into the corresponding slots.
    • The slots are located on the left and right ends of the bottom cover.
  8. Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 8、 2の画像 1 Eureka 169 J 2-in-1 Quick-Up Brush Roll Replacement: 手順 8、 2の画像 2
    • Reattach the cover and screw it back into place using a Phillips #2 screwdriver.
    • The two 4.2 mm Phillips #2 screws go in the two middle bottom holes.
    • The four 3.0 mm Phillips #2 screws go in the side holes.
終わりに
Plug in your device and test it to ensure that you have reassembled it correctly.
作成者
1人の作成者と共同作成されました。
Mark Parala
メンバー登録日: 08/23/22
157 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 1-8, Briggs Fall 2022 CSU Los Angeles, Team 1-8, Briggs Fall 2022人のメンバー
CSULA-BRIGGS-F22S1G8
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 41
今までの合計 758
