メインコンテンツにスキップ
Eureka 1660SP External Start Switch Realignment
必要な工具と部品
  1. Eureka 1660SP External Start Switch Realignment, Motor Housing: 手順 1、 2の画像 1 Eureka 1660SP External Start Switch Realignment, Motor Housing: 手順 1、 2の画像 2
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Eureka 1660SP External Start Switch Realignment: 手順 2、 2の画像 1 Eureka 1660SP External Start Switch Realignment: 手順 2、 2の画像 2
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Eureka 1660SP External Start Switch Realignment: 手順 3、 3の画像 1 Eureka 1660SP External Start Switch Realignment: 手順 3、 3の画像 2 Eureka 1660SP External Start Switch Realignment: 手順 3、 3の画像 3
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  4. Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 手順 4、 3の画像 1 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 手順 4、 3の画像 2 Eureka 1660SP External Start Switch Realignment, Realignment of plastic start switch piece: 手順 4、 3の画像 3
    • If the external switch is slightly misaligned as shown, realign it with the internal switch.
    • Make sure the spring loaded button on the underside of the housing is intact when reassembling the motor housing. It is prone to eject when opening the motor housing.
終わりに
作成者
3人の作成者と共同で作成されました。
Evan Fodi
メンバー登録日: 09/24/13
122 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013人のメンバー
UMASSD-GULBRANDSEN-F13S1G1
3 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 2,444
