メインコンテンツにスキップ
Eton FRX3 LED Flashlight Replacement
必要な工具と部品
  1. Eton FRX3 LED Flashlight Replacement, Rechargeable Battery Pack: 手順 1、 1の画像 1
    • Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
  2. Eton FRX3 LED Flashlight Replacement: 手順 2、 1の画像 1
    • Disconnect the battery pack wires from the device and remove the battery pack.
  3. Eton FRX3 LED Flashlight Replacement, Case Assembly: 手順 3、 1の画像 1
    • On the bottom of the device case's face are two T10 screws. Use a T10 Torx screwdriver to remove the two screws.
  4. Eton FRX3 LED Flashlight Replacement: 手順 4、 1の画像 1
    • While using the T10 screwdriver, remove the two T10 screws on the back of the device's case.
  5. Eton FRX3 LED Flashlight Replacement: 手順 5、 1の画像 1
    • Remove the two Phillips #00 screws located in the center of the back of the device.
    • You will need to use a thin shafted screwdriver or a female hexagonal bit that is found in the iFixit 54 bit toolkit to extend the reach of the Phillips #00 bit.
  6. Eton FRX3 LED Flashlight Replacement: 手順 6、 1の画像 1
    • On the bottom of the device's case there are two rubber feet. Pry the rubber feet off of the case.
    • Try to keep the adhesive on the rubber feet as clean as possible to insure that they can be reattached during reassembly.
  7. Eton FRX3 LED Flashlight Replacement: 手順 7、 1の画像 1
    • Pull the two halves of the device's case apart.
    • Take care when pulling the two halves apart. There are three cables that connect components of the device to the motherboard. Disconnect these cables in order to separate the two halves of the device's case.
  8. Eton FRX3 LED Flashlight Replacement, LED Flashlight: 手順 8、 1の画像 1
    • Pull the LED modules connector from its socket on the mother board.
  9. Eton FRX3 LED Flashlight Replacement: 手順 9、 1の画像 1
    • Gently lift the LED module upwards to remove it.
終わりに
To reassemble your device, follow these instructions in the reverse order.
作成者
4人の作成者と共同で作成されました。
Kenneth Sills
メンバー登録日: 02/10/16
762 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 1-6, Nance Spring 2016 USF Tampa, Team 1-6, Nance Spring 2016人のメンバー
USFT-NANCE-S16S1G6
4 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 15
今までの合計 216
