メインコンテンツにスキップ
Etekcity Lasergrip 1080 Laser Replacement
必要な工具と部品
  1. Etekcity Lasergrip 1080 Laser Replacement, Battery: 手順 1、 1の画像 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Laser Replacement: 手順 2、 1の画像 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Laser Replacement: 手順 3、 2の画像 1 Etekcity Lasergrip 1080 Laser Replacement: 手順 3、 2の画像 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Laser Replacement, Buttons: 手順 4、 2の画像 1 Etekcity Lasergrip 1080 Laser Replacement, Buttons: 手順 4、 2の画像 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Laser Replacement: 手順 5、 2の画像 1 Etekcity Lasergrip 1080 Laser Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Laser Replacement: 手順 6、 1の画像 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Laser Replacement: 手順 7、 2の画像 1 Etekcity Lasergrip 1080 Laser Replacement: 手順 7、 2の画像 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Laser Replacement: 手順 8、 1の画像 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Laser Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 手順 9、 2の画像 1 Etekcity Lasergrip 1080 Laser Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 手順 9、 2の画像 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Laser Replacement, Laser: 手順 10、 1の画像 1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Laser Replacement: 手順 11、 1の画像 1
    • Use a soldering iron to melt the solder that holds the wires for the laser to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
終わりに
作成者
1人の作成者と共同作成されました。
Patrick Crawford
メンバー登録日: 08/26/15
741 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S5G1
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 21
今までの合計 920
