メインコンテンツにスキップ
Etekcity Lasergrip 1080 Battery Connector Replacement
必要な工具と部品
  1. Etekcity Lasergrip 1080 Battery Connector Replacement, Battery: 手順 1、 1の画像 1
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 2、 1の画像 1
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 3、 2の画像 1 Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 3、 2の画像 2
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
  4. Etekcity Lasergrip 1080 Battery Connector Replacement, Buttons: 手順 4、 2の画像 1 Etekcity Lasergrip 1080 Battery Connector Replacement, Buttons: 手順 4、 2の画像 2
    • Remove the battery cover from the device by pulling it straight out.
  5. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 5、 2の画像 1 Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 5、 2の画像 2
    • Using the plastic opening tool remove the front and rear yellow covers.
    • When removing the back cover, be careful not to lose the buttons as they are not connected.
  6. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 6、 1の画像 1
    • Remove the two 3.1 mm Phillips #0 screws.
  7. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 7、 2の画像 1 Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 7、 2の画像 2
    • Pull the two halves apart.
    • Be careful not to lose any components on the inside.
  8. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 8、 1の画像 1
    • Realign the buttons with the button terminals.
    • Red terminal to red button.
    • Orange terminal to orange button.
    • Yellow terminal to yellow button.
  9. Etekcity Lasergrip 1080 Battery Connector Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 手順 9、 2の画像 1 Etekcity Lasergrip 1080 Battery Connector Replacement, Etekcity Lasergrip 1080 Trigger Replacement: 手順 9、 2の画像 2
    • Carefully pull the trigger out.
    • The trigger is spring loaded, so be careful that you do not lose the spring as you pull the trigger out.
    • To put the trigger back in, align the peg with the hole in the handle and align the shaft with the button terminal.
  10. Etekcity Lasergrip 1080 Battery Connector Replacement, Battery Connector: 手順 10、 1の画像 1
    • Pull the motherboard out of its slot in the device.
  11. Etekcity Lasergrip 1080 Battery Connector Replacement: 手順 11、 1の画像 1
    • Use a soldering iron and melt the solder where the battery connector's wires are attached to the motherboard.
    • Soldering irons are hot and should only be handled by those who know what they are doing and are wearing proper safety equipment. There is a link to a soldering guide in the Troubleshooting section of the device page.
終わりに
作成者
3人の作成者と共同で作成されました。
Patrick Crawford
メンバー登録日: 08/26/15
741 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 5-1, Blackwell Fall 2015 USF Tampa, Team 5-1, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S5G1
3 メンバー
9のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 727
