1. remove the battery door using either your finger nail or a screwdriver. remove the battery door using either your finger nail or a screwdriver. remove the battery door using either your finger nail or a screwdriver.
    • remove the battery door using either your finger nail or a screwdriver.
  2. Then remove the three screws on the back cover using a philips screwdriver #1. Then remove the three screws on the back cover using a philips screwdriver #1.
    • Then remove the three screws on the back cover using a philips screwdriver #1.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Remove the black back cover with your hand and be careful not to cut the wires attached on the cover.
    • Remove the black back cover with your hand and be careful not to cut the wires attached on the cover.
  5. Using a screwdriver #1, remove the 2 small screws located at the top and bottom of the alarm switch. Using a screwdriver #1, remove the 2 small screws located at the top and bottom of the alarm switch.
    • Using a screwdriver #1, remove the 2 small screws located at the top and bottom of the alarm switch.
  6. Using soldering iron, detach wire end from the copper cylinder by plaint the end of the iron to the end of the wire. Now you can replace the alarm switch with a new one by attaching one end of the wires to the copper cylinder . Then install the switch screws using the screwdriver. Using soldering iron, detach wire end from the copper cylinder by plaint the end of the iron to the end of the wire. Now you can replace the alarm switch with a new one by attaching one end of the wires to the copper cylinder . Then install the switch screws using the screwdriver.
    • Using soldering iron, detach wire end from the copper cylinder by plaint the end of the iron to the end of the wire. Now you can replace the alarm switch with a new one by attaching one end of the wires to the copper cylinder . Then install the switch screws using the screwdriver.
  7. a photo of the steps we have been through in working on the clock and a photo of the tools we used and the clock parts during disassembly a photo of the steps we have been through in working on the clock and a photo of the tools we used and the clock parts during disassembly
    • a photo of the steps we have been through in working on the clock and a photo of the tools we used and the clock parts during disassembly
まとめ
Alaa
メンバー登録日: 2014年10月27日
228 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 1-6, Carnegie Fall 2014 Eastern Washington University, Team 1-6, Carnegie Fall 2014人のメンバー
EWU-CARNEGIE-F14S1G6
6 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 400
