メインコンテンツにスキップ
Epson Stylus Photo 1400 Ink cartridge replacement
必要な工具と部品
  1. Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: 手順 1、 2の画像 1 Epson Stylus Photo 1400 Ink cartridge replacement, ink cartridge: 手順 1、 2の画像 2
    • Open cover of the printer.
    • Open the cartridge cover by pressing down on the tab and lifting it up.
  2. Epson Stylus Photo 1400 Ink cartridge replacement: 手順 2、 2の画像 1 Epson Stylus Photo 1400 Ink cartridge replacement: 手順 2、 2の画像 2
    • Grab the sides of the ink cartridge and pull it out.
    • Replace ink cartridge with brand new ink cartridge.
  3. Epson Stylus Photo 1400 Ink cartridge replacement: 手順 3、 2の画像 1 Epson Stylus Photo 1400 Ink cartridge replacement: 手順 3、 2の画像 2
    • Close cartridge cover.
    • Close cover of the printer.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Larry Huang
メンバー登録日: 10/12/11
1,004 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011人のメンバー
CPSU-REGAN-F11S17G11
4 メンバー
12のガイドは作成済み
5 件のコメント
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
David Hardy - 返信
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
chrishowell562 - 返信
You missed the part where you tell people how to get the cartridge to a position where you can open it. Mine is block because it is over to the side too far.
Paul M - 返信
Poor instructions on how to get ink cartridge holder in right position.
rpttrsn - 返信
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
joe waldroff - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 23
今までの合計 10,070
