Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Locate the IEEE cover in the back.
Gently slide the cover to the right to unlatch, then pull to remove it.
Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
Remove the 6 mm screw that holds the rear housing in place.
Insert a plastic opening tool into the cutouts of the lower housing.
Release the two tabs of the side housing by lifting the tool in an upward motion.
Remove the side housing by pulling it outwards.
Both side housings are attached by the same type of mechanism.
Using the same method, remove the other side housing.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
