メインコンテンツにスキップ
Epson Stylus NX240 Side Buttons Replacement
必要な工具と部品
  1. Epson Stylus NX240 Side Buttons Replacement, Side Buttons: 手順 1、 2の画像 1 Epson Stylus NX240 Side Buttons Replacement, Side Buttons: 手順 1、 2の画像 2
    • Go to the left side of the printer and locate the control panel with the buttons on it.
    • Take a plastic opening tool and stick it in the crack between the top of the panel and the body of the printer.
    • Pry the cover of the panel away from the body of the printer until the panel releases from the body of the printer.
  2. Epson Stylus NX240 Side Buttons Replacement: 手順 2、 1の画像 1
    • Carefully lift up the panel cover and turn it to its side so that the buttons are facing towards the rest of the printer.
    • Notice that the panel cover is attached to the printer with a ribbon cable. The ribbon cable must stay connected to the body of the printer or else the buttons will be unresponsive once replaced.
  3. Epson Stylus NX240 Side Buttons Replacement: 手順 3、 1の画像 1
    • Remove the six 3mm Phillips #2 screws connecting the control panel to the circuit board.
  4. Epson Stylus NX240 Side Buttons Replacement: 手順 4、 1の画像 1
    • After unscrewing, carefully lift the plastic part of the control panel away from the circuit board.
    • The plastic part of the control panel is now separate.
  5. Epson Stylus NX240 Side Buttons Replacement: 手順 5、 1の画像 1
    • Flip over the plastic part of the now separated control panel.
    • Remove the buttons by pulling them up with your fingers.
  6. Epson Stylus NX240 Side Buttons Replacement: 手順 6、 1の画像 1
    • All parts should be separate now to clean or replace.
終わりに
作成者
2人の作成者と共同で作成されました。
Joshua Fabel
メンバー登録日: 10/13/16
104 ポイント
1ガイドが承認済み
チーム
University of Maine, Team 2-4, Diaz Fall 2016 University of Maine, Team 2-4, Diaz Fall 2016人のメンバー
UMAINE-DIAZ-F16S2G4
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 588
