メインコンテンツにスキップ
Epson Stylus NX230 Ink Cartridge Replacement
  1. Epson Stylus NX230 Ink Cartridge Replacement, Ink Cartridge: 手順 1、 1の画像 1
    • Open the top of the printer so that the inside of the printer is visible. Press the red button.
    • The ink cartridges should be visible.
  2. Epson Stylus NX230 Ink Cartridge Replacement: 手順 2、 1の画像 1
    • Grab the top of the cartridge that you need to replace and press in on the tab at the top of the cartridge.
    • Pull the cartridge up and out of the ink tray
終わりに
Close the cover and hit the red button one last time. It will now move to the park position and "CHARGE" the cartridges.
5 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Danielle Purdy
メンバー登録日: 04/07/14
309 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014人のメンバー
CPSU-FORTE-S14S6G1
4 メンバー
10のガイドは作成済み
9 件のコメント
I tried cartridge 124 and 125 in black only (and it says ink cartridge not recognized and won't print even if the black cartridges are full). But I left the color ones empty! Do ALL of the cartridges have to be full in order for the printer to work?? I only do black and white print jobs so it doesn't make sense for me to buy color ink. Thanks a lot!!
kathleenngomez - 返信
no idea why replacing these cartridges was so confusing to me - but this article REALLY helped, thank you!
hi - 返信
When I tried these instructions the very first thing I tried did not work. The cartridges were not in the center, they were on the right side of the machine and I couldn’t get to them. Any suggestions?
Doris Crowley - 返信
When I tried these instructions the very first thing I tried did no work. The cartridges were not in the center, they were on the right side of the machine and I couldn’t get to them. Any suggestions?
Doris Crowley - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 11,380
