メインコンテンツにスキップ
Epson Stylus NX230 Front Button Replacement
必要な工具と部品
  1. Epson Stylus NX230 Front Button Replacement, Front Buttons: 手順 1、 1の画像 1
    • Before beginning, make sure the printer is unplugged and turned off to avoid electric shock.
    • Lift the top of the printer to see the inside.
  2. Epson Stylus NX230 Front Button Replacement: 手順 2、 3の画像 1 Epson Stylus NX230 Front Button Replacement: 手順 2、 3の画像 2 Epson Stylus NX230 Front Button Replacement: 手順 2、 3の画像 3
    • Locate the control panel, the part of the printer with the buttons on it.
    • Push the control panel away from the outside of the printer, taking the panel out of the holes that hold it in place.
    • Repeat the above step for the other side of the control panel.
  3. Epson Stylus NX230 Front Button Replacement: 手順 3、 2の画像 1 Epson Stylus NX230 Front Button Replacement: 手順 3、 2の画像 2
    • The front control panel is attached to the printer on both sides by a grey piece of plastic that runs on a track. Remove the control panel from the track by pushing it away from the track on both sides.
    • The ribbon cable on the left side of the control panel, also known as the ribbon cable, must stay attached to the printer. If the cable becomes detached the front buttons will not be responsive.
  4. Epson Stylus NX230 Front Button Replacement: 手順 4、 1の画像 1
    • Flip the detached control panel over so that the buttons are facing down.
    • Remove the two 3mm Phillips #2 screws from the back of the control panel.
  5. Epson Stylus NX230 Front Button Replacement: 手順 5、 1の画像 1
    • Lift up the gray plastic piece.
    • Remove the 3mm Phillips #2 screw.
  6. Epson Stylus NX230 Front Button Replacement: 手順 6、 1の画像 1
    • Split the control panel in half by gently pulling on both sides of the seam that runs through the control panel.
  7. Epson Stylus NX230 Front Button Replacement: 手順 7、 2の画像 1 Epson Stylus NX230 Front Button Replacement: 手順 7、 2の画像 2
    • Separate the two pieces to reveal the green circuit board.
    • Be sure to not detach the circuit board from the white tap.
    • Remove the green circuit board by lifting it up gently with your hands.
  8. Epson Stylus NX230 Front Button Replacement: 手順 8、 1の画像 1
    • Remove the buttons with the plastic opening tool by pressing the front panel down and lifting the buttons up.
終わりに
To reassemble your device, follow these instructions in the reverse order.
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Danielle Purdy
メンバー登録日: 04/07/14
309 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-1, Forte Spring 2014 Cal Poly, Team 6-1, Forte Spring 2014人のメンバー
CPSU-FORTE-S14S6G1
4 メンバー
10のガイドは作成済み
コメント 1 件
Wow! this guide is clear and concise. wahoo!!!
kyle price - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 823
