ツール
ツールは指定されていません。
  1. When the red light is flashing, one or more ink cartridges are low.  When the red ink light stays on, at least one cartridge needs to be replaced. Turn off the printer. The power light should be on, but not flashing. Make sure the output tray is lowered. Then open the printer cover. Open the printer and move the carriage with the ink cartridges to the left so you have access to them.
    • When the red light is flashing, one or more ink cartridges are low. When the red ink light stays on, at least one cartridge needs to be replaced.
    • Turn off the printer. The power light should be on, but not flashing. Make sure the output tray is lowered. Then open the printer cover.
    • Open the printer and move the carriage with the ink cartridges to the left so you have access to them.
  2. Pinch the back tab of the empty cartridge as you lift it out of the printer. Don't take the used cartridge apart or try to refill it. Don't take the used cartridge apart or try to refill it.
    • Pinch the back tab of the empty cartridge as you lift it out of the printer.
    • Don't take the used cartridge apart or try to refill it.
  3. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  4. Shake the new cartridge inside the packaging four or five times before installing it. This will keep your hands clean and loosen the ink. Turn off the printer. The power light should be on, but not flashing. Make sure the output tray is lowered. Then open the printer cover.
    • Shake the new cartridge inside the packaging four or five times before installing it. This will keep your hands clean and loosen the ink.
    • Press the ink button for one second. The print head moves to the left, and the cartridge that needs to be replaced stops under the need ink mark. The power light also begins to flash.
  5. Place the cartridge into the cartridge holder. Push down gently until the cartridge is firmly seated. You will hear a click. Close the cartridge cover.
    • Place the cartridge into the cartridge holder. Push down gently until the cartridge is firmly seated. You will hear a click.
    • Close the cartridge cover.
    • Close the printer cover and press the ink button for one second. The printer head will move as the new ink system is formatted.
    • The green power light will flash and the printer will make noise. It will take about a minute and once finished, the power light will stop flashing.
まとめ
ある他の人がこのガイドを完成しました。
Sarah
メンバー登録日: 2013年10月07日
246 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2012 UMass Dartmouth, Team 1-3, Gulbrandsen Fall 2012人のメンバー
UMASSD-GULBRANDSEN-F12S1G3
1 メンバー
2のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 539
