メインコンテンツにスキップ
Epiphone Les Paul Guitar String Replacement
必要な工具と部品
  1. Epiphone Les Paul Guitar String Replacement, Guitar String: 手順 1、 1の画像 1
    • Loosen the first sting you would like to replace by turning the corresponding knob counter-clockwise.
    • Do NOT loosen/remove all strings at once! The lack of tension will cause the neck of the guitar to bend, and the guitar will have trouble staying in tune.
  2. Epiphone Les Paul Guitar String Replacement: 手順 2、 1の画像 1
    • Pull string away from the rest of the strings and snip it with the wire cutters.
    • String may go flying and will be sharp. Be careful.
  3. Epiphone Les Paul Guitar String Replacement: 手順 3、 1の画像 1
    • Remove the cut string from the bridge of the guitar and its corresponding spoke.
  4. Epiphone Les Paul Guitar String Replacement: 手順 4、 2の画像 1 Epiphone Les Paul Guitar String Replacement: 手順 4、 2の画像 2
    • Lead new string through bridge and then spoke. Leave plenty of slack in the string.
    • Strings will be color coded by the bead on the end of it, and the pack of strings will tell you which string goes where.
  5. Epiphone Les Paul Guitar String Replacement: 手順 5、 2の画像 1 Epiphone Les Paul Guitar String Replacement: 手順 5、 2の画像 2
    • Use your right hand to hold the slack near the bridge, and use your left hand to tightly pull the string through the spoke while turning the knob with the fingers of your left hand.
    • This may feel uncomfortable, and will also take the longest out of all the steps.
  6. Epiphone Les Paul Guitar String Replacement: 手順 6、 1の画像 1
    • Once the string starts getting tight and your right hand is no longer needed to hold slack, start tuning the string to the note you want it at.
    • You can use a tuner or your ear. This site can prove to be helpful: How to Tune a Guitar
終わりに
Have fun playing with your new bright-sounding guitar.
9 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Matthew Thomas
メンバー登録日: 02/24/15
335 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 24-3, Green Winter 2015 Cal Poly, Team 24-3, Green Winter 2015人のメンバー
CPSU-GREEN-W15S24G3
5 メンバー
5のガイドは作成済み
コメント 1 件
Thank you very much. First time changing the strings to a guitar, unfortunately I'm a moron and broke the D String :\
Luigi - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 60
過去 30 日: 217
今までの合計 17,648
