メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
  1. Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver. The two screws for the back cover are: 1.5mm diameter x 3.5mm long
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Pry along the edge of the device to separate the back cover from the device. The speakers are attached to the back cover and motherboard assembly so remove carefully. The speakers are attached to the back cover and motherboard assembly so remove carefully.
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Check to see if the wires of the speakers are connected to the motherboard assembly here.
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
終わりに
nbach
メンバー登録日: 2015年03月23日
663 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 3-2, Duarte Spring 2015 UMass Dartmouth, Team 3-2, Duarte Spring 2015人のメンバー
UMASSD-DUARTE-S15S3G2
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 82
