メインコンテンツにスキップ
Engage Wired Optical Mouse Upper Board Removal
必要な工具と部品
  1. Engage Wired Optical Mouse Upper Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 手順 1、 1の画像 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Engage Wired Optical Mouse Upper Board Removal: 手順 2、 1の画像 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Engage Wired Optical Mouse Upper Board Removal: 手順 3、 3の画像 1 Engage Wired Optical Mouse Upper Board Removal: 手順 3、 3の画像 2 Engage Wired Optical Mouse Upper Board Removal: 手順 3、 3の画像 3
    • Grab the top shell of the mouse and lift up to remove.
  4. Engage Wired Optical Mouse Upper Board Removal: 手順 4、 1の画像 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Engage Wired Optical Mouse Upper Board Removal: 手順 5、 2の画像 1 Engage Wired Optical Mouse Upper Board Removal: 手順 5、 2の画像 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Engage Wired Optical Mouse Upper Board Removal, Top Shell: 手順 6、 1の画像 1
    • Remove the 5 mm round head screw holding the middle piece to the top piece.
    • The outermost shell will now separate from the middle structure.
  7. Engage Wired Optical Mouse Upper Board Removal, Upper Board: 手順 7、 1の画像 1
    • Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
  8. Engage Wired Optical Mouse Upper Board Removal: 手順 8、 2の画像 1 Engage Wired Optical Mouse Upper Board Removal: 手順 8、 2の画像 2
    • Pinch the cage to release snaps. You can now pull the cage off.
  9. Engage Wired Optical Mouse Upper Board Removal: 手順 9、 1の画像 1
    • Remove the screw holding the circuit board down.
    • The board will now pop off easily.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
David
メンバー登録日: 01/16/13
1,256 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G36
3 メンバー
30のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 22
今までの合計 914
