メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Energizer Power and Play Wireless Charging System for Wii Batteries Replacement
必要な工具と部品
  1. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement, Energizer Power and Play Induction Charging Battery Pack: 手順 1、 2の画像 1 Energizer Power and Play Wireless Charging System for Wii Batteries Replacement, Energizer Power and Play Induction Charging Battery Pack: 手順 1、 2の画像 2
    • Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
    • The batteries used by the factory are underpowered 600mAh rechargeables. I highly recommend replacing them with at least 850mAh ones, the higher the better.
  2. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 手順 2、 1の画像 1
    • Pull out the battery from the case. It should slide out easily.
  3. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 手順 3、 1の画像 1
    • Using your fingernail or a small screwdriver, carefully separate the two halves of the battery casing. These aren't glued and should separate with little effort.
  4. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 手順 4、 1の画像 1
    • Remove the two batteries, noting their orientation.
    • Clean up any leaking battery acid and/or corrosion.
    • Out of the dozen or so battery packs I have repaired, every single one had failed due to corrosion. This occurred even in units that were just a few months old.
  5. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 手順 5、 1の画像 1
    • Once the contacts and compartment are clean, insert your new rechargeable batteries.
  6. Energizer Power and Play Wireless Charging System for Wii Batteries Replacement: 手順 6、 1の画像 1
    • Re-insert the screws. The battery pack will only fit in one direction.
    • While you are at it, clean the outer contacts and bend them out a little. This can help eliminate remotes having poor battery life.
終わりに
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
10 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Arcane Scroll
メンバー登録日: 12/10/13
931 ポイント
2のガイドは作成済み
4件のガイドコメント
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Mike Propp - 返信
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
martinlu82 - 返信
I have done all the cleaning and battery replacement but still not charging,I think it is the actual battery pack holder where could I buy two new ones
Andrew - 返信
Thanks. Just found my Wii after many years in storage. Thought I would have to toss all the controllers but now, maybe not. On the charger now so, fingers crossed. Thanks again.
Elton Broderick - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 45
過去 30 日: 189
今までの合計 36,086
