メインコンテンツにスキップ
Enagic Water Filter SD501 Platinum Filter Replacement
必要な工具と部品
  1. Enagic Water Filter SD501 Platinum Filter Replacement, Filter: 手順 1、 1の画像 1
    • Turn off and unplug the machine before cleaning it.
    • Clean the machine with a damp cloth or paper towel.
    • Make sure nothing dirty will get in the machine during the process.
  2. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 2、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 2、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 2、 3の画像 3
    • Open the filter door by pushing the "Push" button.
  3. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 3、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 3、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 3、 3の画像 3
    • Turn the ring at the bottom of the filter to the left until you hear a "click".
  4. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 4、 2の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 4、 2の画像 2
    • Remove the ring for now.
  5. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 5、 2の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 5、 2の画像 2
    • Lift up the old filter and discard or recycle appropriately.
    • Some water might be dripping out from the bottom of it. Have a towel ready to clean it up.
  6. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 6、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 6、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 6、 3の画像 3
    • Remove the two black rubber rings.
    • They are NOT components of the machine. The new filter you have prepared should come with new ones.
  7. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 7、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 7、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 7、 3の画像 3
    • Put your new filter in it.
    • Make sure that the two holes match the two popped-out parts from the filter.
    • The one that is bigger should be on the middle and the smaller one should be on the side.
    • This filter should be the new one that you have prepared and NOT the one that is removed from Step 5.
  8. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 8、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 8、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 8、 3の画像 3
    • Put the ring component back in.
    • Turn it to your right until you hear a click.
    • Make sure it is successfully locked in.
  9. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 9、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 9、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 9、 3の画像 3
    • Turn the filter back on.
    • Press the "Reset Switch"
    • "FILTER RESET" should be shown on the display.
  10. Enagic Water Filter SD501 Platinum Filter Replacement: 手順 10、 3の画像 1 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 10、 3の画像 2 Enagic Water Filter SD501 Platinum Filter Replacement: 手順 10、 3の画像 3
    • Attach the filter door.
    • There are three holes to slide the door edge into.
    • And push the "push" button to close it.
終わりに
To change another filter, simply just follow the instructions once more.
作成者
1人の作成者と共同作成されました。
Edwin Ng
メンバー登録日: 09/12/21
181 ポイント
1ガイドが承認済み
チーム
York University, Team 1-16, O'Regan Fall 2021 York University, Team 1-16, O'Regan Fall 2021人のメンバー
YORK-O'REGAN-F21S1G16
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 60
今までの合計 1,709
