メインコンテンツにスキップ
Emerson Ceiling Fan Flywheel Replacement
必要な工具と部品
  1. Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 手順 1、 3の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 手順 1、 3の画像 2 Emerson Ceiling Fan  Flywheel Replacement, Remove Ceiling Fan Blades: 手順 1、 3の画像 3
    • Make sure power to the ceiling fan is off!
    • Use a Phillips #0 screwdriver to remove the ten 12.7 mm screws from the ceiling fan blades.
    • It is easier to work on the ceiling fan if you remove the motor.
  2. Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: 手順 2、 2の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Open Switch Housing: 手順 2、 2の画像 2
    • Remove light bulbs before working on switch housing.
    • Open the switch housing using a Phillips #0 screwdriver to remove the three 7.9 mm screws.
  3. Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: 手順 3、 2の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Disconnect Wires: 手順 3、 2の画像 2
    • Disconnect wires that are attached to the switch housing and the motor.
    • Make sure you know where to reconnect them.
  4. Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 手順 4、 3の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 手順 4、 3の画像 2 Emerson Ceiling Fan  Flywheel Replacement, Remove Broken Flywheel: 手順 4、 3の画像 3
    • Remove the broken flywheel.
    • Make note of its exact placement on the shaft.
    • It may be a good idea to mark the location with a marker.
  5. Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 手順 5、 3の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 手順 5、 3の画像 2 Emerson Ceiling Fan  Flywheel Replacement, Attach New Flywheel: 手順 5、 3の画像 3
    • Slide the new flywheel into place making sure all the holes line up.
    • Place any wires through the same holes as they were before
    • Replace any other parts you removed during the process.
  6. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: 手順 6、 2の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Wires: 手順 6、 2の画像 2
    • Reconnect the wires from the switch housing to the motor.
    • Make sure you connect the wires to the correct match.
  7. Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 手順 7、 3の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 手順 7、 3の画像 2 Emerson Ceiling Fan  Flywheel Replacement, Close Switch Housing: 手順 7、 3の画像 3
    • Screw back on the three 7.9 mm screws to the switch housing using a Phillips #0 screwdriver.
    • Screw the light bulbs back in.
  8. Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 手順 8、 3の画像 1 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 手順 8、 3の画像 2 Emerson Ceiling Fan  Flywheel Replacement, Reconnect Ceiling Fan Blades: 手順 8、 3の画像 3
    • Using a Phillips #0 screwdriver, reconnect ceiling fan blades by re-screwing on ten 12.7 mm Phillip screws.
    • If you removed the motor, reconnect it after blades are on.
終わりに
Test your fan. It should be running quietly with no problems. If something is wrong make sure to double check you hooked the wires up correctly.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Tanner Brook
メンバー登録日: 10/21/19
178 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team S27-G4, Munoz Fall 2019 Eastern Washington University, Team S27-G4, Munoz Fall 2019人のメンバー
EWU-MUNOZ-F19S27G4
2 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 32
過去 30 日: 123
今までの合計 3,810
