はじめに
This repair guide will teach you how to replace the battery in the Ematic Genesis 2 tablet.
必要な工具と部品
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
Once all solder is gone, remove the wires from the device to free the battery.
2 の人々がこのガイドを完成させました。
