はじめに
This repair guide will teach you how to replace the battery in the Ematic Genesis 2 tablet.
必要な工具と部品
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
この手順で使用する道具:Desoldering Pump$3.99
Carefully remove the solder that connects the battery wires to the device using the solder sucker tool and a soldering iron.
Once all solder is gone, remove the wires from the device to free the battery.
2 の人々がこのガイドを完成させました。
