Turn off the device before starting
To prevent damage, open the device on the side without the buttons.
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
Insert the hook side of the opening tool between the case and display.
Press down on the tool until the screen is clear of the white retaining tabs.
Use the plastic opening tool to gently pry up the screen.
This is best done on the corner closest to the wire ribbon.
Continue prying around the screen until the screen pops out.
After the screen has come lose, remove it from the device.
When reassembling, make sure the screen locks in place, this may require extra pressure
Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
