この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If your device remains blank or seems to not power on when pressing the power button, a screen replacement may be necessary. If the device's display is damaged, this guide will show you the steps to replacing your defective screen. After following the necessary steps to remove the battery and motherboard, replacing the screen is very quick.
必要な工具と部品
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
Insert the hook side of the opening tool between the case and display.
Press down on the tool until the screen is clear of the white retaining tabs.
Use the plastic opening tool to gently pry up the screen.
Continue prying around the screen until the screen pops out.
