メインコンテンツにスキップ
Ematic FunTab 3 Touch Screen Replacement
必要な工具と部品
  1. Ematic FunTab 3 Touch Screen Replacement, Back Panel: 手順 1、 3の画像 1 Ematic FunTab 3 Touch Screen Replacement, Back Panel: 手順 1、 3の画像 2 Ematic FunTab 3 Touch Screen Replacement, Back Panel: 手順 1、 3の画像 3
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Touch Screen Replacement: 手順 2、 1の画像 1
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Touch Screen Replacement, Motherboard: 手順 3、 1の画像 1
    • Remove the black tape to reveal the screen connector.
  4. Ematic FunTab 3 Touch Screen Replacement: 手順 4、 2の画像 1 Ematic FunTab 3 Touch Screen Replacement: 手順 4、 2の画像 2
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
  5. Ematic FunTab 3 Touch Screen Replacement: 手順 5、 2の画像 1 Ematic FunTab 3 Touch Screen Replacement: 手順 5、 2の画像 2
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
  6. Ematic FunTab 3 Touch Screen Replacement: 手順 6、 1の画像 1
    • It is now safe to remove and replace the old motherboard with your new motherboard.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
  7. Ematic FunTab 3 Touch Screen Replacement, Touch Screen: 手順 7、 2の画像 1 Ematic FunTab 3 Touch Screen Replacement, Touch Screen: 手順 7、 2の画像 2
    • Insert the hook side of the opening tool between the case and display.
    • Press down on the tool until the screen is clear of the white retaining tabs.
    • Use the plastic opening tool to gently pry up the screen.
    • This is best done on the corner closest to the wire ribbon.
    • Continue prying around the screen until the screen pops out.
  8. Ematic FunTab 3 Touch Screen Replacement: 手順 8、 1の画像 1
    • After the screen has come lose, remove it from the device.
    • When reassembling, make sure the screen locks in place, this may require extra pressure
    a mi se me quebro la pantalla tactil. es la misma tecnica para cambiar la pantalla quebrada??
    Skitch - 返信
    Where can I get a new display for my emoticons funtab 3?
    DanTheMan RBLX - 返信
終わりに
作成者
3人の作成者と共同で作成されました。
Amanda Davis
メンバー登録日: 07/11/18
581 ポイント
5のガイドは作成済み
チーム
UW Tacoma, Team S1-G5, Cardinal Summer 2018 UW Tacoma, Team S1-G5, Cardinal Summer 2018人のメンバー
UWT-CARDINAL-SU18S1G5
4 メンバー
12のガイドは作成済み
コメント 1 件
DanTheMan RBLX - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 901
