Turn off the device before starting
To prevent damage, open the device on the side without the buttons.
Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
Slide the plastic opening tool down the long side of the device.
Insert tool again and slide it down the long slide of the case a second time.
Flip up the black retaining tab using the plastic opening tool.
Pull out the large wire ribbon that crosses over the battery.
You may need tweezers to pull out the wire ribbon.
Insert the plastic opening tool under the battery.
Using the plastic opening tool, pry up the battery.
There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
After the connections are desoldered, remove the battery.
Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
このガイドを埋め込む
ご自身のサイト/フォーラムに小さなウィジェットとしてこのガイドを埋め込むには、サイズを選択し下のコードをコピーしてください。
プレビュー
