メインコンテンツにスキップ
Eluktronics N850HK SSD Replacement
必要な工具と部品
  1. Eluktronics N850HK SSD Replacement, SSD: 手順 1、 3の画像 1 Eluktronics N850HK SSD Replacement, SSD: 手順 1、 3の画像 2 Eluktronics N850HK SSD Replacement, SSD: 手順 1、 3の画像 3
    • Push both switch locks inward to unlock the battery from the bottom panel.
    • The switch on the left must be held in place.
    • Remove the battery from the back of the laptop.
  2. Eluktronics N850HK SSD Replacement: 手順 2、 2の画像 1 Eluktronics N850HK SSD Replacement: 手順 2、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the twelve 4 mm screws from the bottom panel of the laptop.
  3. Eluktronics N850HK SSD Replacement: 手順 3、 2の画像 1 Eluktronics N850HK SSD Replacement: 手順 3、 2の画像 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws located under where the battery usually rests.
    • Do not remove the two additional screws near the bottom screw. These are connected to the motherboard and do not need to be removed.
  4. Eluktronics N850HK SSD Replacement: 手順 4、 2の画像 1 Eluktronics N850HK SSD Replacement: 手順 4、 2の画像 2
    • Lift the back case off and identify the SSD in the lower right corner.
    • Although the chances of damage are low, it is important to be aware of static electricity in your surroundings when working a computer motherboard. Ground yourself or use an anti-static wrist strap.
  5. Eluktronics N850HK SSD Replacement: 手順 5、 3の画像 1 Eluktronics N850HK SSD Replacement: 手順 5、 3の画像 2 Eluktronics N850HK SSD Replacement: 手順 5、 3の画像 3
    • Use a Phillips #00 screwdriver to remove 3 mm screw securing the SSD.
    • The SSD will naturally lift by a few millimeters.
    • Carefully slide the SSD from the M.2 slot.
  6. Eluktronics N850HK SSD Replacement: 手順 6、 3の画像 1 Eluktronics N850HK SSD Replacement: 手順 6、 3の画像 2 Eluktronics N850HK SSD Replacement: 手順 6、 3の画像 3
    • Use the ridges on the right side to align the SSD properly.
    • Slide the new SSD into the M.2 mounting slot.
    • Use the Phillips #00 screwdriver to replace the 3 mm screw that secures the SSD.
  7. Eluktronics N850HK SSD Replacement: 手順 7、 3の画像 1 Eluktronics N850HK SSD Replacement: 手順 7、 3の画像 2 Eluktronics N850HK SSD Replacement: 手順 7、 3の画像 3
    • Reassemble by following the directions in reverse order.
終わりに
Alternative models where this guide may still apply:
  • Eluktronics N857HK1
  • Eluktronics N850HP6
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Brandon Yuan
メンバー登録日: 06/22/24
226 ポイント
1ガイドが承認済み
チーム
Austin Community College, Team 6-12, Watkins Summer 2024 Austin Community College, Team 6-12, Watkins Summer 2024人のメンバー
AUSTINCC-WATKINS-SU24S6G12
1 メンバー
4のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 83
過去 30 日: 349
今までの合計 4,218
