はじめに
Use this guide to access the headphone jack and check soldered connections. If you are planning to follow this replacement guide, you should have identified the headphone jack as a source of a problem (or maybe you just want to see the guts of your Element GC-1020).
必要な工具と部品
Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
この手順で使用する道具:Tweezers$4.99
Desolder the four points where it is soldered to the motherboard.
When completed pull the headphone jack off using tweezers and replace.
ある他の人がこのガイドを完成しました。
