メインコンテンツにスキップ
Electrohome EAAC475 USB Port Replacement
必要な工具と部品
  1. Electrohome EAAC475 USB Port Replacement, Battery: 手順 1、 2の画像 1 Electrohome EAAC475 USB Port Replacement, Battery: 手順 1、 2の画像 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 USB Port Replacement: 手順 2、 1の画像 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 USB Port Replacement, Buttons: 手順 3、 2の画像 1 Electrohome EAAC475 USB Port Replacement, Buttons: 手順 3、 2の画像 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 USB Port Replacement: 手順 4、 3の画像 1 Electrohome EAAC475 USB Port Replacement: 手順 4、 3の画像 2 Electrohome EAAC475 USB Port Replacement: 手順 4、 3の画像 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 USB Port Replacement: 手順 5、 2の画像 1 Electrohome EAAC475 USB Port Replacement: 手順 5、 2の画像 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 USB Port Replacement, USB Port: 手順 6、 1の画像 1
    • Locate the screw holding the USB circuit board in place.
    • Take a Philips head screwdriver and remove the 10 mm screw.
  7. Electrohome EAAC475 USB Port Replacement: 手順 7、 1の画像 1
    • Upon removing the screw, the circuit board should slide right out to look like this.
    • The USB port is to the right in this picture.
  8. Electrohome EAAC475 USB Port Replacement: 手順 8、 1の画像 1
    • Find the pins of the USB port that are soldered into the circuit board.
    • Compare the new port with the old port to be sure which pins to work with.
    • Take the soldering gun and heat up the pins one at a time.
    • If you are not familiar with soldering, consult a more skilled individual or at least a how-to guide.
    • Use solder wick with each pin to remove the solder.
    • Remove the USB port.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Sterling Fulk
メンバー登録日: 02/16/16
264 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 14
今までの合計 270
