メインコンテンツにスキップ
Electrohome EAAC475 Speaker Replacement
必要な工具と部品
  1. Electrohome EAAC475 Speaker Replacement, Battery: 手順 1、 2の画像 1 Electrohome EAAC475 Speaker Replacement, Battery: 手順 1、 2の画像 2
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: 手順 2、 1の画像 1
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: 手順 3、 2の画像 1 Electrohome EAAC475 Speaker Replacement, Buttons: 手順 3、 2の画像 2
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: 手順 4、 3の画像 1 Electrohome EAAC475 Speaker Replacement: 手順 4、 3の画像 2 Electrohome EAAC475 Speaker Replacement: 手順 4、 3の画像 3
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: 手順 5、 2の画像 1 Electrohome EAAC475 Speaker Replacement: 手順 5、 2の画像 2
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: 手順 6、 2の画像 1 Electrohome EAAC475 Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: 手順 7、 1の画像 1
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: 手順 8、 1の画像 1
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: 手順 9、 1の画像 1
    • Detach the wires on the speaker and replace them with new ones.
終わりに
作成者
4人の作成者と共同で作成されました。
Ruolin Cai
メンバー登録日: 02/16/16
273 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 2-1, Harley Spring 2016 IUPUI, Team 2-1, Harley Spring 2016人のメンバー
IUPUI-HARLEY-S16S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 15
今までの合計 392
