メインコンテンツにスキップ
Electrical Outlet/Receptacle Replacement
必要な工具と部品
  1. Electrical Outlet/Receptacle Replacement, Outlet/Receptacle: 手順 1、 1の画像 1
    • Before beginning this guide, read your local laws to decide if you are legally allowed to replace an outlet
    • Turn off the power to the outlets by switching off all breakers that are labelled "receptacle."
    • Alternatively, you can switch off all breakers.
  2. Electrical Outlet/Receptacle Replacement: 手順 2、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 2、 2の画像 2
    • Using a flat-head screwdriver, remove the outer cover plate of the outlet by unscrewing the middle screw.
  3. Electrical Outlet/Receptacle Replacement, Determine voltage absence: 手順 3、 2の画像 1 Electrical Outlet/Receptacle Replacement, Determine voltage absence: 手順 3、 2の画像 2
    • Use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
    • You can also use a single pole phase tester, but that's not the proper way to do it.
    • Do not work on live circuits if you are not an experienced professional.
  4. Electrical Outlet/Receptacle Replacement: 手順 4、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 4、 2の画像 2
    • Unscrew the top and bottom screws holding the outlet into the interior electrical box.
    • The screws on outlets vary. They may have either a phillips head or a flat head, so use the screwdriver that works with your screws
  5. Electrical Outlet/Receptacle Replacement: 手順 5、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 5、 2の画像 2
    • Holding the top and bottom tabs of the outlet, pull the outlet away from the wall, exposing the wires inside the electrical box.
  6. Electrical Outlet/Receptacle Replacement: 手順 6、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 6、 2の画像 2
    • Unscrew each screw and free the wire from under it.
    • Styles that have wires inserted into the back of the outlet will require you to pull and twist the outlet to free the wires.
  7. Electrical Outlet/Receptacle Replacement: 手順 7、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 7、 2の画像 2
    • If your wires already have hooks on the ends, you may skip to step 10.
    • Using a pair of wire strippers, place the wire into each groove, closing the wire strippers around the wire to find the size that barely does not fit around the wires.
    • In the United States, residential wires are typically 12 gauge or 14 gauge, denoted by 12 and 14 on the wire strippers.
  8. Electrical Outlet/Receptacle Replacement: 手順 8、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 8、 2の画像 2
    • For each wire, approximately 0.75 inches (2 centimeters) away from the clipped end of the wire, clamp the strippers down on the wire and pull the strippers toward the clipped end of the wire, revealing the bare wire underneath.
  9. Electrical Outlet/Receptacle Replacement: 手順 9、 3の画像 1 Electrical Outlet/Receptacle Replacement: 手順 9、 3の画像 2 Electrical Outlet/Receptacle Replacement: 手順 9、 3の画像 3
    • For each wire, using a pair of wire strippers or pliers, take hold of the exposed tip of the wire, and curve the tip of the wire, making a small hook.
    • Separate the wires so that the black wires are on the right and the rest are on the left, with the ground wire at the bottom.
  10. Electrical Outlet/Receptacle Replacement: 手順 10、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 10、 2の画像 2
    • Retrieve the new outlet.
  11. Electrical Outlet/Receptacle Replacement: 手順 11、 1の画像 1
    • Loosen all of the screws on the new outlet
  12. Electrical Outlet/Receptacle Replacement: 手順 12、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 12、 2の画像 2
    • Hold the outlet with face of the outlet pointing toward you, with the copper screws on the right, and the silver screws on the left.
  13. Electrical Outlet/Receptacle Replacement: 手順 13、 1の画像 1
    • Hook each black wire around a copper screw, with the hook clockwise, and tighten the screw down.
  14. Electrical Outlet/Receptacle Replacement: 手順 14、 1の画像 1
    • Hook each white wire around a silver screw, with the hook clockwise. Tighten the screws down completely
  15. Electrical Outlet/Receptacle Replacement: 手順 15、 1の画像 1
    • Hook the ground wire around the screw that is separate from all other screws, and tighten the screw down.
  16. Electrical Outlet/Receptacle Replacement: 手順 16、 1の画像 1
    • Push the outlet and wires back into the electrical box.
  17. Electrical Outlet/Receptacle Replacement: 手順 17、 2の画像 1 Electrical Outlet/Receptacle Replacement: 手順 17、 2の画像 2
    • Fully tighten the screws on the top and bottom tabs, positioning the outlet so that it is straight, vertically.
  18. Electrical Outlet/Receptacle Replacement: 手順 18、 3の画像 1 Electrical Outlet/Receptacle Replacement: 手順 18、 3の画像 2 Electrical Outlet/Receptacle Replacement: 手順 18、 3の画像 3
    • Retrieve the outlet cover plate, and tighten the middle screw to the middle of the outlet.
  19. Electrical Outlet/Receptacle Replacement: 手順 19、 1の画像 1
    • Switch on all the breakers that you turned off in step 1.
ゴール
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tyler Wallace
メンバー登録日: 10/29/19
426 ポイント
1ガイドが承認済み
チーム
University of Memphis, Team S1-G3, Willis Fall 2019 University of Memphis, Team S1-G3, Willis Fall 2019人のメンバー
UM-WILLIS-F19S1G3
1 メンバー
1のガイドは作成済み
3 件のコメント
pictures tell the story in the right manner, easy to do.
Thanks from Aria electical
aria electrical - 返信
This is a great step by step guide. I wish I had this a couple of years ago. I knocked myself off a ladder because I thought the power was off... didn't test it... and got super lucky. Don't be like me... spend the money on a voltage tester to make sure it isn't live.
Michelle - 返信
if you are in the fullerton ca area and we can help... check us out at http://fullertonElectricpros.com
Michelle -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 51
今までの合計 1,904
