メインコンテンツにスキップ
Electric Lint Remover Blade Replacement
必要な工具と部品
  1. Electric Lint Remover Blade Replacement, Blade: 手順 1、 2の画像 1 Electric Lint Remover Blade Replacement, Blade: 手順 1、 2の画像 2
    • Remove the lint container by sliding to the right until it clicks off.
    • Remove any lint from the lint container for a clean process.
  2. Electric Lint Remover Blade Replacement: 手順 2、 3の画像 1 Electric Lint Remover Blade Replacement: 手順 2、 3の画像 2 Electric Lint Remover Blade Replacement: 手順 2、 3の画像 3
    • Rotate the perforated cap counterclockwise until it can be removed.
  3. Electric Lint Remover Blade Replacement: 手順 3、 2の画像 1 Electric Lint Remover Blade Replacement: 手順 3、 2の画像 2
    • Use your flathead screwdriver to get in between the device and the blades.
    • Push the plastic blade holder outward from the device until it pops off.
  4. Electric Lint Remover Blade Replacement: 手順 4、 2の画像 1 Electric Lint Remover Blade Replacement: 手順 4、 2の画像 2
    • Lift the wire out of the defective blade's hole, using the flathead screwdriver.
  5. Electric Lint Remover Blade Replacement: 手順 5、 3の画像 1 Electric Lint Remover Blade Replacement: 手順 5、 3の画像 2 Electric Lint Remover Blade Replacement: 手順 5、 3の画像 3
    • Insert the replacement blade into the empty slot.
    • Caution: pinching the replacement blade from surface may result in injury.
  6. Electric Lint Remover Blade Replacement: 手順 6、 2の画像 1 Electric Lint Remover Blade Replacement: 手順 6、 2の画像 2
    • Flip the cap onto its backside and firmly hold down the side with the loose blade.
    • Pull back the wire using your fingers, and insert wire back into the blade hole.
  7. Electric Lint Remover Blade Replacement: 手順 7、 3の画像 1 Electric Lint Remover Blade Replacement: 手順 7、 3の画像 2 Electric Lint Remover Blade Replacement: 手順 7、 3の画像 3
    • Insert the plastic blade holder back on the shaft of the device, by aligning the hexagonal hole on the cap with the shaft.
    • Press down gently on the plastic blade cap.
    • Caution: Make sure to press on the cap and not on the blades, otherwise action may cause injury.
  8. Electric Lint Remover Blade Replacement: 手順 8、 2の画像 1 Electric Lint Remover Blade Replacement: 手順 8、 2の画像 2
    • Place perforated cap on top of the blade cap and turn clockwise until tight.
  9. Electric Lint Remover Blade Replacement: 手順 9、 2の画像 1 Electric Lint Remover Blade Replacement: 手順 9、 2の画像 2
    • Slide the lint container to the left and press until it clicks into place.
終わりに
We hope this guide helped you. Happy Fixing!
作成者
3人の作成者と共同で作成されました。
Chris Koenig
メンバー登録日: 10/03/23
169 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 9-4, Ribeiro Fall 2023 CSU Los Angeles, Team 9-4, Ribeiro Fall 2023人のメンバー
CSULA-RIBEIRO-F23S9G4
3 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 34
今までの合計 212
