メインコンテンツにスキップ
Electric Eel Lower Feeder Assembly Replacement
必要な工具と部品
  1. Electric Eel Lower Feeder Assembly Replacement, Remove the Guide Spring: 手順 1、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement, Remove the Guide Spring: 手順 1、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement, Remove the Guide Spring: 手順 1、 3の画像 3
    • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
    • Wear gloves to protect your hands from injury when handling the cable.
    • Ensure the cable is completely retracted into the auto-feeder.
    • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
    • Remove the guide spring.
  2. Electric Eel Lower Feeder Assembly Replacement, Release the Tension Spring: 手順 2、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement, Release the Tension Spring: 手順 2、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement, Release the Tension Spring: 手順 2、 3の画像 3
    • Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
  3. Electric Eel Lower Feeder Assembly Replacement, Set the Feeder in Neutral Position: 手順 3、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement, Set the Feeder in Neutral Position: 手順 3、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement, Set the Feeder in Neutral Position: 手順 3、 3の画像 3
    • Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
  4. Electric Eel Lower Feeder Assembly Replacement, Disengage the Top Bearing: 手順 4、 2の画像 1 Electric Eel Lower Feeder Assembly Replacement, Disengage the Top Bearing: 手順 4、 2の画像 2
    • Push the top control finger up as far as possible.
    • This disengages the top feeder assembly and allows the cable to freely move through the feeder. The finger may fall back down on its own and restrict cable movement. If this occurs, simply push the finger back up.
  5. Electric Eel Lower Feeder Assembly Replacement, Remove the Auto-Feeder: 手順 5、 1の画像 1
    • Use a 1/2" open-ended wrench to remove the two bolts from the bottom of the feeder body mounting arm.
  6. Electric Eel Lower Feeder Assembly Replacement: 手順 6、 2の画像 1 Electric Eel Lower Feeder Assembly Replacement: 手順 6、 2の画像 2
    • Remove the auto-feeder from the cable.
    • If the end of the cable won't pass through the feeder, ensure that the top bearing is completely disengaged as described in step 4 of this guide.
  7. Electric Eel Lower Feeder Assembly Replacement, Install the Roll Pin: 手順 7、 1の画像 1
    • Use a vise to compress the roll pin until there is no longer space in the roll pin's slot.
  8. Electric Eel Lower Feeder Assembly Replacement: 手順 8、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement: 手順 8、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement: 手順 8、 3の画像 3
    • Use a dead blow hammer or mallet to tap down the bearing carrier onto the roll pin until the pin just begins to peek into the bearing channel.
    • Ensure you are using the correct bearing carrier for this step. The top bearing assembly uses the shorter carrier, while the two lower bearing assemblies use the longer carrier.
  9. Electric Eel Lower Feeder Assembly Replacement: 手順 9、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement: 手順 9、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement: 手順 9、 3の画像 3
    • Insert a bearing and the bearing spacer into the bearing channel.
    • Ensure that the bearing and spacer are aligned with the roll pin and hole in the bearing carrier.
  10. Electric Eel Lower Feeder Assembly Replacement: 手順 10、 1の画像 1
    • Continue to tap down the bearing carrier until the bearing and spacer are fully secured around the roll pin.
    • You will need to unclamp and reposition the roll pin upwards to continue tapping it into the bearing carrier. Do this as many times as is necessary to sufficiently support the roll pin.
  11. Electric Eel Lower Feeder Assembly Replacement: 手順 11、 1の画像 1
    • Use a roll pin punch to finish seating the roll pin into place.
    • Place a piece of cloth or mat on top of the vise below the bearing carrier to prevent marring the outer surface of the bearing carrier.
    • Before moving to the next step, ensure the roll pin is fully seated and completely within the bearing carrier. A slightly exposed roll pin may damage the inside of your feeder body when the bearing carrier assembly is being installed.
  12. Electric Eel Lower Feeder Assembly Replacement, Remove the Retaining Ring: 手順 12、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement, Remove the Retaining Ring: 手順 12、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement, Remove the Retaining Ring: 手順 12、 3の画像 3
    • Use a pair of snap ring pliers to remove the retaining ring at the bottom of the lower feeder assembly.
  13. Electric Eel Lower Feeder Assembly Replacement, Remove the Thrust Bearings: 手順 13、 2の画像 1 Electric Eel Lower Feeder Assembly Replacement, Remove the Thrust Bearings: 手順 13、 2の画像 2
    • Use a pair of needle-nose pliers to remove the first thrust washer from the assembly.
  14. Electric Eel Lower Feeder Assembly Replacement: 手順 14、 2の画像 1 Electric Eel Lower Feeder Assembly Replacement: 手順 14、 2の画像 2
    • Remove the thrust bearing from the assembly.
  15. Electric Eel Lower Feeder Assembly Replacement: 手順 15、 2の画像 1 Electric Eel Lower Feeder Assembly Replacement: 手順 15、 2の画像 2
    • Remove the second thrust washer from the assembly.
  16. Electric Eel Lower Feeder Assembly Replacement, Remove the Control Finger: 手順 16、 1の画像 1
    • Use a flathead screwdriver to remove the lower control finger from the assembly.
  17. Electric Eel Lower Feeder Assembly Replacement, Remove the Bearing Carrier Assembly: 手順 17、 3の画像 1 Electric Eel Lower Feeder Assembly Replacement, Remove the Bearing Carrier Assembly: 手順 17、 3の画像 2 Electric Eel Lower Feeder Assembly Replacement, Remove the Bearing Carrier Assembly: 手順 17、 3の画像 3
    • Use a flathead screwdriver or other long tool as leverage to remove the lower bearing carrier from the assembly.
終わりに
After reassembly: Ensure the assembly you just installed is sufficiently lubricated using the Zerk fitting on the feeder body.
ある他の人がこのガイドを完成しました。
Tarun Thiruma
メンバー登録日: 11/20/19
39,342 ポイント
134のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 36
今までの合計 1,698
