はじめに
Follow this guide to remove the Auto-Feed mechanism from your Electric Eel 75’ Drain Cleaner Z5K12IC75AF for replacement or further disassembly.
必要な工具と部品
Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
Remove the guide spring.
Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
Use a 1/2" open-ended wrench to remove the two bolts from the bottom of the feeder body mounting arm.
ある他の人がこのガイドを完成しました。
