はじめに
This guide shows how to remove and disassemble the joystick from the controller. This will allow the user to clean under the joystick or replace it.
Warning: Use caution when placing the joystick face down on the table. The joystick can crack if placed down too hard. Be sure to gently turn the device over and place it face down. It can be helpful to balance the other side of the device to distribute the weight.
必要な工具と部品
Place the controller face down (buttons and joystick down).
Use a Phillips Head #1 screwdriver to remove the eight 9.65mm screws located on the felt and metal backplate.
Insert a #4 Flat Head screwdriver into the shaft of the joystick and grasp the ball topper with your other hand.
Turn the flat head screwdriver counter clockwise for a quarter turn while tightly holding the ball topper.
The ball topper should now be loose enough to unscrew by hand.
Set aside the shaft cover, dust cover, and ball topper.
ある他の人がこのガイドを完成しました。
