はじめに
This guide will show you how to replace the speakers inside the tablet. Its is important to do these steps carefully, as they the electrical components inside the device are more fragile than the case.
必要な工具と部品
Power down your device.
Place the small suction cup on a corner of the screen and lightly pull up to expose a seam between the screen and case.
Remove the battery (secured by six screws and a white wire connector) by following the removal portion of this battery replacement guide.
Remove the wires connecting the speakers to the motherboard by pushing the small tab until the connection is broken.
ある他の人がこのガイドを完成しました。
