はじめに
The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the wheels are jammed, the Deebot will not be able to clean around your house. Use this guide to replace the wheel of the Ecovacs Deebot 900.
必要な工具と部品
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.
6 の人々がこのガイドを完成させました。
6 件のコメント
Thanks, it helps a lot
I have an OZMO 930 that the left driver wheel is stuck. I tried to follow the above instruction, but I can’t go beyond step 10, I can’t take out the cover. Any help will be greatly appreciated,
do you have place to buy ecovac_deebot_900_54_gear ?? I thinking on printing it but after my printed gear to papper shreder I have no hopes it will last.
