はじめに
The Ecovacs Deebot 900 is an autonomous vacuuming robot. If the vacuum motor is not working, the Deebot will not pick up debris and will be unable to clean. Use this guide to replace the vacuum motor of your Ecovacs Deebot 900.
必要な工具と部品
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
5 の人々がこのガイドを完成させました。
