メインコンテンツにスキップ
Ecovacs Deebot 900 Vacuum Motor Replacement
必要な工具と部品
  1. Ecovacs Deebot 900 Vacuum Motor Replacement, Battery: 手順 1、 1の画像 1
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 2、 1の画像 1
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 3、 1の画像 1
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 4、 1の画像 1
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 5、 1の画像 1
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Vacuum Motor Replacement, Front Bumper: 手順 6、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement, Front Bumper: 手順 6、 2の画像 2
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 7、 1の画像 1
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 8、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 8、 2の画像 2
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 9、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 9、 2の画像 2
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
  10. Ecovacs Deebot 900 Vacuum Motor Replacement, Bottom Case: 手順 10、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement, Bottom Case: 手順 10、 2の画像 2
    • Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
  11. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 11、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 11、 2の画像 2
    • Insert a Jimmy into the seam and work all the way around the robot.
    • Disconnect the two cables and remove the bottom case from the device.
  12. Ecovacs Deebot 900 Vacuum Motor Replacement, Vacuum Motor: 手順 12、 1の画像 1
    • Using the Phillips #00 screwdriver, remove the three screws around the laser unit.
  13. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 13、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 13、 2の画像 2
    • Carefully lift the laser unit off of the motor assembly​.
  14. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 14、 1の画像 1
    • Remove the single screw holding the motor assembly in place using the Phillips #00 screwdriver.
  15. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 15、 2の画像 1 Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 15、 2の画像 2
    • Disconnect the ribbon cable holding the assembly in place.
    • Be careful not to damage the cable.
  16. Ecovacs Deebot 900 Vacuum Motor Replacement: 手順 16、 1の画像 1
    • Lift and remove the motor assembly out of the Deebot.​
終わりに
5 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Gillian Blumer
メンバー登録日: 01/16/20
555 ポイント
3のガイドは作成済み
チーム
コメント 1 件
Where can you find a replacement vacuum motor for the zoom 930?
Aaron Commons - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 18
過去 30 日: 98
今までの合計 10,977
