メインコンテンツにスキップ
EasySMX ESM-9110 Vibration Motor Replacement
必要な工具と部品
  1. EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: 手順 1、 2の画像 1 EasySMX ESM-9110 Vibration Motor Replacement, Handle Covers: 手順 1、 2の画像 2
    • Use a Phillips #000 screwdriver to remove the two 10 mm screws from the back of controller.
  2. EasySMX ESM-9110 Vibration Motor Replacement: 手順 2、 1の画像 1
    • Insert a plastic opening tool into the slit on the side of controller.
    • Wiggle the tool until the cover becomes loose.
    • Repeat this on the other side of Controller.
    • Go slow. Take your time removing the handle covers.
  3. EasySMX ESM-9110 Vibration Motor Replacement: 手順 3、 1の画像 1
    • Remove the faceplate.
    • Repeat on the other side of the controller.
  4. EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: 手順 4、 3の画像 1 EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: 手順 4、 3の画像 2 EasySMX ESM-9110 Vibration Motor Replacement, Vibration Motor: 手順 4、 3の画像 3
    • Use a Phillips #000 screwdriver to remove the four 20 mm screws from the controller's faceplate.
    • Use a Phillips #000 screwdriver (a screwdriver bit extension may be needed) to remove the two 20 mm screws from the controllers faceplate.
    • The screw extender should only be used to unscrew two of the six screws. Do not use it for all six.
  5. EasySMX ESM-9110 Vibration Motor Replacement: 手順 5、 2の画像 1 EasySMX ESM-9110 Vibration Motor Replacement: 手順 5、 2の画像 2
    • Remove the faceplate of the controller by lifting it directly up from the backplate.
    • Be gentle, the controller's backplate is still attached. Do not move the controller too roughly.
  6. EasySMX ESM-9110 Vibration Motor Replacement: 手順 6、 2の画像 1 EasySMX ESM-9110 Vibration Motor Replacement: 手順 6、 2の画像 2
    • Locate the parts of the vibration motor that are connected to the motherboard
    • Solder these parts of the vibration motor to remove them.
    • There should be two connectors present in your controller, one for each vibration motor.
終わりに
作成者
2人の作成者と共同で作成されました。
Melanie Rodriguez
メンバー登録日: 03/18/24
406 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 2-4, Konn Spring 2024 UMass Dartmouth, Team 2-4, Konn Spring 2024人のメンバー
UMASSD-KONN-S24S2G4
4 メンバー
5のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 279
